[mapserver-users] CLASS directive
Matt Bartolome
mattxbart at gmail.com
Tue Apr 26 18:07:11 EDT 2011
On Tue, Apr 26, 2011 at 11:46 AM, Mark Korver <mwkorver at gmail.com> wrote:
> Maybe you can just define the layer 2X in the mapfile. Put the
> altered layer on top of the regular layer? I am assuming that you can
> get the good values to be transparent and not white.
Thanks Mark! This works great.
> On Tue, Apr 26, 2011 at 11:57 AM, Matt Bartolome <mattxbart at gmail.com>
> wrote:
> > Hello,
> > I have a funky raster I'm trying to tile as jpegs. For whatever reason
> this
> > RGB raster has white pixels on the source raster which should be black.
> Is
> > it possible to set only these white pixels to be black on the output
> jpeg? I
> > was playing around with the CLASS directive. This sets all those white
> > pixels to black, but it does not preserve the rest of the rgb that I want
> to
> > use; those "good" values are not processed and show as blank (white)
> space.
> > How do I do this? I thought of preprocessing this with gdalwarp but the
> > raster becomes too large (source is an ecw) on output so need to do it
> > on-the-fly with mapserver (I'm using mapserver trunk and gdal 1.8 on
> linux).
> > Thanks!
> > Matt
> > OUTPUTFORMAT
> > NAME jpeg
> > DRIVER "AGG/JPEG"
> > MIMETYPE "image/jpeg"
> > IMAGEMODE RGB
> > EXTENSION "jpg"
> > END
> > LAYER
> > NAME "test"
> > TYPE RASTER
> > STATUS ON
> > DATA "/test.tif"
> > PROJECTION
> > "init=epsg:2230"
> > END
> > PROCESSING "NODATA=255"
> > CLASS
> > NAME "set white to black"
> > EXPRESSION ([red] = 255 AND [green] = 255 AND [blue] = 255)
> > STYLE
> > COLOR 0 0 0
> > END
> > END
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110426/381cb2bf/attachment.html
