[mapserver-users] CLASS directive
Mark Korver
mwkorver at gmail.com
Tue Apr 26 14:46:34 EDT 2011
Maybe you can just define the layer 2X in the mapfile. Put the
altered layer on top of the regular layer? I am assuming that you can
get the good values to be transparent and not white.
On Tue, Apr 26, 2011 at 11:57 AM, Matt Bartolome <mattxbart at gmail.com> wrote:
> Hello,
> I have a funky raster I'm trying to tile as jpegs. For whatever reason this
> RGB raster has white pixels on the source raster which should be black. Is
> it possible to set only these white pixels to be black on the output jpeg? I
> was playing around with the CLASS directive. This sets all those white
> pixels to black, but it does not preserve the rest of the rgb that I want to
> use; those "good" values are not processed and show as blank (white) space.
> How do I do this? I thought of preprocessing this with gdalwarp but the
> raster becomes too large (source is an ecw) on output so need to do it
> on-the-fly with mapserver (I'm using mapserver trunk and gdal 1.8 on linux).
> Thanks!
> Matt
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "AGG/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> LAYER
> NAME "test"
> TYPE RASTER
> STATUS ON
> DATA "/test.tif"
> PROJECTION
> "init=epsg:2230"
> END
> PROCESSING "NODATA=255"
> CLASS
> NAME "set white to black"
> EXPRESSION ([red] = 255 AND [green] = 255 AND [blue] = 255)
> STYLE
> COLOR 0 0 0
> END
> END
> mapserver-users at lists.osgeo.org
