[mapserver-users] Re: Postgis -> Mapserver white background
Ben Madin
lists at remoteinformation.com.au
Wed Apr 27 03:45:27 EDT 2011
Graham,
It looks OK to me. Although the brevity is good, it might help if you could also attach the table definition - is it just producing a blank png image? is it in the same projection etc...? How are you accessing it (ie through WMS, mapscript or standard mapserver output).
I've also copied this back to MapServer list...
cheers
Ben
On 27/04/2011, at 3:26 PM, Graham Walker wrote:
> Hi all, fairly new to all this. I was wondering if you could help me
> with the following issue. I can't seem to display my postgis table in
> mapserver. I can display shapefiles and html templates fine, but when
> I try to connect to my postgis table I simply get a white background
> (or whatever colour I set it as).
> I have managed to display postgis tables before in mapserver, but I am
> having no luck in this one and cannot see any differences. Both the
> shapefile and postgis table can display in qgis. My map file is listed
> below. I have intentionally tried to simplify this down to the basics
> so it has no projection details, etc at present. Any help would be
> greatly appreciated. Thanks
> MAP
> NAME "test"
> IMAGETYPE PNG
> SIZE 400 500
> STATUS ON
> EXTENT 200949 883531 347001 979508
> SHAPEPATH "C:\ms4w\Apache\htdocs\test"
> UNITS METERS
> END
> WEB
> IMAGEPATH "c:\ms4w\tmp\ms_tmp\"
> IMAGEURL "/ms_tmp/"
> END
> #Region Polygons
> LAYER
> NAME "North"
> CONNECTIONTYPE postgis
> CONNECTION "user=postgres password=1
> dbname=test host=localhost port=5432"
> DATA "the_geom from North"
> TYPE POLYGON
> STATUS DEFAULT
> CLASS
> STYLE
> COLOR 1 1 1
> OUTLINECOLOR 1 1 1
> END
> END
> END
> postgis-users mailing list
