[mapserver-users] Re: Postgis -> Mapserver white background
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 27 09:26:08 EDT 2011
Graham,
Postgresql normally assumes table and column names will be in lower case
and if not you need to quote them. So try:
DATA ""the_geom from north"
and/or (notice the quoting below)
DATA 'the_geom from "North"'
I think you will find things easier if you keep everything as lower case
schema, table and column names.
-Steve W
On 4/27/2011 3:45 AM, Ben Madin wrote:
> Graham,
> It looks OK to me. Although the brevity is good, it might help if you
> could also attach the table definition - is it just producing a blank
> png image? is it in the same projection etc...? How are you accessing
> it (ie through WMS, mapscript or standard mapserver output).
> I've also copied this back to MapServer list...
> cheers
> Ben
> On 27/04/2011, at 3:26 PM, Graham Walker wrote:
>> Hi all, fairly new to all this. I was wondering if you could help
>> me with the following issue. I can't seem to display my postgis
>> table in mapserver. I can display shapefiles and html templates
>> fine, but when I try to connect to my postgis table I simply get a
>> white background (or whatever colour I set it as).
>> I have managed to display postgis tables before in mapserver, but I
>> am having no luck in this one and cannot see any differences. Both
>> the shapefile and postgis table can display in qgis. My map file is
>> listed below. I have intentionally tried to simplify this down to
>> the basics so it has no projection details, etc at present. Any
>> help would be greatly appreciated. Thanks
>> MAP NAME "test" IMAGETYPE PNG SIZE 400 500 STATUS ON EXTENT
>> 200949 883531 347001 979508 SHAPEPATH "C:\ms4w\Apache\htdocs\test"
>> UNITS METERS END
>> WEB IMAGEPATH "c:\ms4w\tmp\ms_tmp\" IMAGEURL "/ms_tmp/" END
>> #Region Polygons LAYER NAME "North" CONNECTIONTYPE postgis
>> CONNECTION "user=postgres password=1 dbname=test host=localhost
>> port=5432" DATA "the_geom from North" TYPE POLYGON STATUS DEFAULT
>> CLASS STYLE COLOR 1 1 1 OUTLINECOLOR 1 1 1 END END END
>> _______________________________________________ postgis-users
>> mailing list postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> _______________________________________________ mapserver-users
> mailing list mapserver-users at lists.osgeo.org
