[mapserver-users] multiple layers in a class
Fawcett, David (MPCA)
david.fawcett at state.mn.us
Wed Apr 27 15:35:44 EDT 2011
Mukesh,
If you want to symbolize SMALL PIG and BIG PIG differently, you will need two classes. A class is used to select features that match the (optional) class expression.
You can have multiple styles within a class, but they would be applied equally to all of the features in that class. One example might be stacking symbols for a feature.
The docs don’t say that you can have multiple ‘layers’ within a class, but that you can have multiple ‘styles’ applied within a class. http://mapserver.org/mapfile/style.html
In your description below, you are conceptually talking about having different classes within a layer, but just using different words. Is there a reason that you have an aversion to using multiple classes?
You can group classes if there is a need for it. http://mapserver.org/mapfile/class.html
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mukesh Subedee
Sent: Wednesday, April 27, 2011 2:06 PM
To: mapserver mailing list
Subject: [mapserver-users] multiple layers in a class
In the STYLE documentation, it is mentioned that it is possible to have multiple layers within a class. I could not find any example how it can be implemented. I was checking an example in http://lists.osgeo.org/pipermail/mapserver-users/2010-August/066303.html where "SMALL PIG" and "BIG PIG" are in two different classes. However I am wondering if it is possible to implement it within a same class but representing with different styles. It means representing two different "PIG" in a same class but with different coloring mechanisms.
Thanks,
Mukesh
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110427/00c29e58/attachment.html
