[mapserver-users] free() methods in MapScript,	compatibility MS 5.x and 6
    Alan Boudreault
    aboudreault at mapgears.com
    Fri Apr 29 06:13:53 PDT 2011
Hi Armin,
Although I'm not sure if the free call was useful... since it was only
removing the php object from a global list but the object was not really freed
until the end of the script... I would suggest to simply add a such condition
"if ms_version < 6 ... obj->free()" rather than removing them to be compatible
5.6/6.0 and avoid any issue. You can also do a quick test in your script with
some echo of the memory used before the end of the script and see if the
free() removal has any effect.
Alan
On April 27, 2011 01:25:54 pm Armin Burger wrote:
> Hi everybody
> in MapServer/MapScript 6 the various class methods "free()" have been
> removed. If I want to have PHP/MapScript code compatible with both
> MapServer 5.x and 6, the easiest would be to completely remove these
> method calls from the code.
> My question is just if these free() methods are still somehow required
> or recommended for MapServer/MapScript 5.x or if I can silently drop
> them without any drawbacks.
> Cheers
> Armin
> mapserver-users at lists.osgeo.org
Alan Boudreault
Mapgears
http://www.mapgears.com
More information about the MapServer-users
