[mapserver-users] Parameterized MapFile using CGI variable
Nicolas BOUTET
nicolas.boutet at geosys.com
Fri Apr 29 09:56:56 EDT 2011
Dear All,
I have 2 MapServer servers. One for Production use, and the other for
Validation use.
The MAP files placed on those servers are similar except that each server
has a different Oracle database as datasource.
For now, I have some different CONNECTION values depending if the map file
is on the Production or on the Validation server. So finally I must have
different MAP files.
Is there a way to have exactly the same map files on the 2 servers, and to
use a variable to parameterize the CONNECTION.
For example, I would like to set the CONNECTION of my layers to
"%ORACLECONNECTIONSTRING%" and to set a CGI Environment variable named
ORACLECONNECTIONSTRING to the correct value on each server.
Nicolas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110429/5750ea20/attachment.html
