[mapserver-users] ArcSDE, Win32 and truncated GetCapabilities
Stephan Holl
stephan.holl at intevation.de
Tue Aug 9 02:40:01 EDT 2011
Hello Steve,
thanks for your answer,
Steve Lime <sdlime at gmail.com>, [20110809 - 01:13:43]
> I wonder if this could be related to some general issues we've been
> experiencing with with SDE and queries. Get capabilities obviously
> doesn't do a query but it might be getting a list of attributes for
> presentation. That's where the issue seems to be. Check out ticket
> #3977. I've applied a fix to branch-6-0 only but it's trivial to fix
> trunk too if you can compile from source. I was waiting on some
> testing feedback before applying more broadly.
Ahh, I see. I will pull out a patch[1] and try to apply on trunk since I
have a recent trunk build-env. Reading the ticket seems the exact same
problem I am facing. Btw. GetFeatureInfo also returns the famous 500
Premature End of script... error.
Probably related.
Best
Stephan
[1] http://trac.osgeo.org/mapserver/changeset/12031
> On Mon, Aug 8, 2011 at 4:30 AM, Stephan Holl
> <stephan.holl at intevation.de>wrote:
> > Hello,
> > since there is no reply for some time now I follow up to myself
> > here.
> > Stephan Holl <stephan.holl at intevation.de>, [20110728 - 10:15:14]
> > > Dear list,
> > > I have an ArcSDE-Layer-based mapfile. When requesting a
> > > GetCapabilities-doc in Version 1.1.1 and 1.3.0, the output gets
> > > truncated.
> > > In 1.0.0 the GetCapabilities-Document is finished though, strange.
> > > I am running MapServer 6.1-dev (r11785) on Windows 7 with Apache
> > > 2.2.19 against ArcSDE 9.3.1.
> > > I found some quite old issues[1],[2] which seem to have the same
> > > problem, but apparently they are fixed.
> > It seems that mapserver segfaults here (no errors given in any
> > logfile with DEBUG 5 in web and layer-level) or the GetCaps-buffer
> > is to small for the output..
> > Can anybody provide some debug-hints on windows though?
> > Best
> > Stephan
> > Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508
> > 3663 Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück -
> > HR B 18998 Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr.
> > Jan-Oliver Wagner
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110809/0b16aa14/signature.bin
