[mapserver-users] SLD and LABEL MINDISTANCE ..?
Julien Cigar
jcigar at ulb.ac.be
Wed Aug 10 06:04:12 EDT 2011
On 08/09/2011 13:23, Julien Cigar wrote:
> Hello,
> I'm using SLD with a <TextSymbolizer> section for labeling my polygons
> (this is what I have at the moment http://www.pastie.org/2344427). It
> works well except that I miss the MINDISTANCE of the LABEL section and
> wondered if there is a way to do it in the SLD ..? Does Mapserver
> supports some <VendorOption> that are undocumented? Is there a way to
> "mix" a LABEL section (in the .map file) with the SLD?
> Thanks,
> Julien
apparently it's not possible to use a SLD and CLASS/LABEL definitions
together, when I specify a SLD my LABEL definition in my mapfile is
simply ignored.. too bad :(
> mapserver-users at lists.osgeo.org
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110810/36d2847a/jcigar.vcf
