[mapserver-users] RE: WCS GetCoverage
Guillaume Loiselle
loiselle.guillaume at gmail.com
Mon Nov 28 09:08:46 EST 2011
Hi David,
I encounter an issue a few weeks ago that shares similarities with your. I
opened a ticket on the subject and I invite you to add any information you
judge relevant :
http://trac.osgeo.org/mapserver/ticket/4079
You will need an OSGeo login but, don't worry, it is easy to create one.
Guillaume Loiselle
2011/11/24 David Hildebrand <David.Hildebrand at afsc.ca>
> Jukka:
> I am running MapServer 5.2.1 and am being explicit about W** version.
> For WMS I am using version 1.1.1 and WCS version 1.0.0 but that is
> hidden in a CGI wrapper. I did find out, however, that in my WCS
> request I need to specify the RESX and RESY units the same as the CRS
> projection units (in this case degrees) and I also need to specify the
> RESPONSE_CRS the same as the CRS. These are odd behaviours. One should
> be able to request the response in a different projection than the
> bounding box and specify the resolution in the units of the output
> projection. The projections I am using are all specified in the
> "ows_srs" line of the mapserv.map file.
> David V. Hildebrand
> Agriculture Financial Services Corporation
> (403) 782-8239
> -----Original Message-----
> From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
> Sent: Thursday, November 24, 2011 2:06 PM
> To: David Hildebrand; mapserver-users at lists.osgeo.org
> Subject: Re: WCS GetCoverage
> Hi,
> Very first thing to do with all the W** services is to give always an
> explicit VERSION=
> Request can sometimes work even without but then the default is the
> highest supported. Do not play with defaults, take the control for
> yourself.
> What Mapserver version you have? Perhaps some old 5.x which supports
> only WCS 1.0 because otherwise I suppose you would get some other error
> message with your request.
> -Jukka Rahkonen-
> ________________________________
> David Hildebrand wrote:
> I am trying to implement a WCS server and am running into difficulty
> with GetCoverage and the following request.
> REQUEST=GetCoverage&COVERAGE=awifs&CRS=EPSG:4269&BBOX=-116,51,-114,53&RE
> SX=100&RESY=100&FORMAT=GTiff&RESPONSE_CRS=EPSG:4269
> The following ServiceException is raised.
> msImageCreateGD(): Image handling error. Cannot create GD image of size
> 0x0
> I can do a WCS GetCapabilities and DescribeCoverage without error.
> Also, when I issue the following WMS request it works fine.
> REQUEST=GetMap&LAYERS=awifs&SRS=EPSG:4269&BBOX=-116,51,-114,53&WIDTH=800
> &HEIGHT=600&FORMAT=image/png&STYLES=
> The GetCoverage and GetMap requests have the same parameters and yet WCS
> thinks the image size is 0x0. The MapServer configuration for the layer
> file is given below
> LAYER
> NAME "awifs"
> PROCESSING "BANDS=2,1,3"
> PROCESSING "SCALE_2=19,159"
> PROCESSING "SCALE_1=10,130"
> PROCESSING "SCALE_3=9,124"
> METADATA
> "wcs_label" "awifs"
> "wcs_rangeset_name" "RGB"
> "wcs_rangeset_label" "rgb"
> "wms_title" "awifs"
> "wms_opaque" "1"
> "ows_resolution" "56 56"
> "wms_srs" "EPSG:43001"
> END
> STATUS off
> TYPE raster
> DATA "e:/awifs/July.tif"
> PROJECTION
> "init=epsg:43001"
> END
> TEMPLATE "empty.html"
> DUMP TRUE
> END
> Thanks for the help.
> David V. Hildebrand
> (403) 782-8239
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111128/32fcc9bd/attachment.html
