[mapserver-users] Validation error (but working!)
thomas bonfort
thomas.bonfort at gmail.com
Mon Apr 2 04:55:07 EDT 2012
Ben,
if the validation fails, the default_xxx parameter is used instead,
which is why no further errors are reported.
what are you sending in your url for CCODE ?
thomas
On Mon, Apr 2, 2012 at 08:39, Ben Madin <lists at remoteinformation.com.au> wrote:
> G'day all,
> I've noticed that when I turn layer (going out as a WMS service) debugging on, I am getting the messages shown below (the layer is rendering as I expected, with only the names for the selected country showing up).
> As I said, it is working, but what is wrong with my patterns - I suspect other layers with the same validation patterns would be giving the same errors, but I haven't investigated them (as they are working)
> My confusion is :
> Either the validation is working (and the log message is wrong), or
> I am failing to understand how the validation is meant to work, or
> The validation is failing, but not being respected…
> any clues
> cheers
> Ben
> Log messages :
> [Mon Apr 2 14:29:40 2012].960342 runtime substitution - Layer provnames, tag %CCODE%...
> [Mon Apr 2 14:29:40 2012].960725 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
> [Mon Apr 2 14:29:40 2012].960759 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
> [Mon Apr 2 14:29:40 2012].960775 runtime substitution - Layer provnames, tag %YEAR%...
> [Mon Apr 2 14:29:40 2012].961353 msDrawMap(): rendering using outputformat named AGG (AGG/PNG).
> [Mon Apr 2 14:29:40 2012].993291 msPostGISLayerIsOpen called.
> The layer has a validation pattern and defaults set:
> METADATA
> "wms_title" "provnames"
> "wms_srs" "EPSG:4326"
> "wms_group_title" "Administrative"
> "default_ccode" "AUS"
> "default_year" "2010"
> END
> VALIDATION
> 'ccode' '[A-Z]{3}'
> 'year' '20[0-1][0-9]'
> END
> and the query is :
> DATA "geom from (
> SELECT recordid as gid, geom, name as pname
> FROM geolayer
> WHERE validitystarts <= '%YEAR%'
> AND (validityends >= '%YEAR%' OR validityends IS NULL)
> AND country LIKE '%CCODE%'
> ) AS foo USING UNIQUE gid USING SRID=4326"
> TYPE ANNOTATION
> labelmaxscaledenom 5000000
> LABELITEM pname
> CLASS
> LABEL
> COLOR 150 150 250
> OUTLINECOLOR 255 255 255
> FONT "lucida"
> TYPE truetype
> SIZE 9
> POSITION AUTO
> PARTIALS FALSE
> END
> END
> and the version is :
> MapServer version 6.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> mapserver-users at lists.osgeo.org
