[mapserver-users] Validation error (but working!)
Ben Madin
lists at remoteinformation.com.au
Mon Apr 2 09:19:01 EDT 2012
Thanks Thomas,
On 02/04/2012, at 4:55 PM, thomas bonfort wrote:
> if the validation fails, the default_xxx parameter is used instead,
> which is why no further errors are reported.
> what are you sending in your url for CCODE ?
I should have included it - sorry ! The url normally looks like :
maps/index.php?page=details&ccode=EST&mapcode=156&year=2005&submit=submit
'tis unfortunately a local system, and the size of the data files somewhat limits my opportunity to put an example up somewhere.
cheers
Ben
> On Mon, Apr 2, 2012 at 08:39, Ben Madin <lists at remoteinformation.com.au> wrote:
>> G'day all,
>> I've noticed that when I turn layer (going out as a WMS service) debugging on, I am getting the messages shown below (the layer is rendering as I expected, with only the names for the selected country showing up).
>> As I said, it is working, but what is wrong with my patterns - I suspect other layers with the same validation patterns would be giving the same errors, but I haven't investigated them (as they are working)
>> My confusion is :
>> Either the validation is working (and the log message is wrong), or
>> I am failing to understand how the validation is meant to work, or
>> The validation is failing, but not being respected…
>> any clues
>> cheers
>> Ben
>> Log messages :
>> [Mon Apr 2 14:29:40 2012].960342 runtime substitution - Layer provnames, tag %CCODE%...
>> [Mon Apr 2 14:29:40 2012].960725 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
>> [Mon Apr 2 14:29:40 2012].960759 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
>> [Mon Apr 2 14:29:40 2012].960775 runtime substitution - Layer provnames, tag %YEAR%...
>> [Mon Apr 2 14:29:40 2012].961353 msDrawMap(): rendering using outputformat named AGG (AGG/PNG).
>> [Mon Apr 2 14:29:40 2012].993291 msPostGISLayerIsOpen called.
>> The layer has a validation pattern and defaults set:
>> METADATA
>> "wms_title" "provnames"
>> "wms_srs" "EPSG:4326"
>> "wms_group_title" "Administrative"
>> "default_ccode" "AUS"
>> "default_year" "2010"
>> END
>> VALIDATION
>> 'ccode' '[A-Z]{3}'
>> 'year' '20[0-1][0-9]'
>> END
>> and the query is :
>> DATA "geom from (
>> SELECT recordid as gid, geom, name as pname
>> FROM geolayer
>> WHERE validitystarts <= '%YEAR%'
>> AND (validityends >= '%YEAR%' OR validityends IS NULL)
>> AND country LIKE '%CCODE%'
>> ) AS foo USING UNIQUE gid USING SRID=4326"
>> TYPE ANNOTATION
>> labelmaxscaledenom 5000000
>> LABELITEM pname
>> CLASS
>> LABEL
>> COLOR 150 150 250
>> OUTLINECOLOR 255 255 255
>> FONT "lucida"
>> TYPE truetype
>> SIZE 9
>> POSITION AUTO
>> PARTIALS FALSE
>> END
>> END
>> and the version is :
>> MapServer version 6.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
