[mapserver-users] Mapserver MS4W PostGIS 2.0.0
Donald Kerr
donald.kerr at dkerr.co.uk
Mon Apr 23 16:46:26 EDT 2012
John,
I've just installed PostGIS 2.0.0 and I'm getting:
msDrawMap(): Image handling error. Failed to draw layer named 'ABC'.
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
function geomfromtext(unknown, integer) does not exist LINE 1: ...as
geom,"toid" from ABC where geom && GeomFromTe... ^ HINT: No function matches
the given name and argument types. You might need to add explicit type
casts.
>From what I can make out, it appears that "geomfromtext" has changed name in
PostGIS to "ST_GeomFromText". I think "geomfromtext" is hard codeed in
MapServer version 6.0.2 (MS4W 3.0.4).
Many thanks.
Regards,
Donald
-----Original Message-----
From: John Callahan [mailto:john.callahan at udel.edu]
Sent: 23 April 2012 21:23
To: Donald Kerr
Subject: Re: [mapserver-users] Mapserver MS4W PostGIS 2.0.0
I've been using MS4W for a while and the latest versions seem to support
Postgis 2.0 just fine.
- John
John Callahan, Research Scientist
Delaware Geological Survey, University of Delaware
URL: http://www.dgs.udel.edu
On Mon, Apr 23, 2012 at 3:27 PM, Donald Kerr <donald.kerr at dkerr.co.uk>
wrote:
Can anyone give me an idea of timescales for the release of PostGIS 2.0.0
support in Mapserver and then MS4W please?
Many thanks.
Regards,
Donald
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
