[mapserver-users] mapserver crash on wfs query, looks like issue 4166, could someone confirm ?
Oliver Christen
oliver.christen at camptocamp.com
Tue Jul 17 05:08:54 PDT 2012
|dear all
I stumbled upon a Mapserver problem, which looks like the existing bug
https://github.com/mapserver/mapserver/issues/4166
but im not exactly sure,
I would really appreciate if someone could confirm (or not) if that's
what happening in this case.
Here is the problem description:
I have two Shapefile layers.
When I do a wfs query on both of them, Mapserver crash.
(Strangely doing a wfs query on each of them, alone, gives a normal result)
As proposed in the bug description, I replaced the DATA by
CONNECTIONTYPE OGR/CONNECTION and the problem was solved.
This problem could be reproduced with Mapserver 6.0.0 and 6.0.3
I dont really know how to do a WFS query on mapserver using commandline
with gdb so I only have the raw stacktrace:
http://dev.camptocamp.com/files/mapserver/raw_backtrace.txt
thanks in advance for any info
best regards
Oliver
Camptocamp SA
Oliver Christen
PSE A
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120717/c990d9d2/attachment.html>
