[mapserver-users] Opacity change the color
Andrea Peri
aperi2007 at gmail.com
Mon Jul 30 02:39:47 PDT 2012
I discovered just now that the problem is due to qgis.
The last version of wgis-dev available on repository wrong drammatically
the colors when the object has some transparency.
I don't know exactly why this happen.
But now I'm sure that is not a mapserver problem, but instead a qgis-dev
problem.
ps: i notice this happened only with the last actually dev (I use the
qgis-dev 1.9.0 - 540df9c) on windows.
Sorry for noise.
Regards,
2012/7/30 Eichner, Andreas - SID-NLKM <Andreas.Eichner at sid.sachsen.de>
> > OPACITY 10
> > this setting instead of a full blue give a light gray.
> > Instead if I put OPACITY 100 I have correctly a "full blue".
> Opacity 10 is near transparent, so blue it might appear as light gray.
> Have a try with a higher value, let's say 50 or 75 and see if this is
> what you want.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120730/3428d1a0/attachment.html>
