[mapserver-users] GRID - how to display labels not in degrees
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Jun 20 11:41:46 PDT 2012
On 12-06-20 2:30 PM, Alexandre Dube wrote:
> Hi,
> Using the [GRID] object, I'm able to do a GetMap request using
> &SRS=EPSG:900913 to display a the grid correctly reprojected, but the
> coordinates displayed (labels) are in degrees. When switching the layer
> PROJECTION from 4326 to 900913, the request throws a 504 error.
> How can I display them in 900913 ?
> See the attached image and layer definition. I'm using MapServer 6.0.1.
Hello Alexandre,
If I was in this situation I would:
- try to duplicate it with an easy shp2img command (I can locally, using
gmap75 mapfile and setting the projection of the grid layer to 3978
instead of 4326)
- then, once you get that crash with that easy command (yup I get the
crash with MS 6.0.3), I would start to comment all those parameters in
your actual GRID object
- for me, I found that once I commented the M*INTERVAL parameters I was
able to get a valid map image with grid lines nicely labelled in meters
I think there is a ticket/issue here so I think it would be nice to
package a little test case that throws this crash.
Happy first day of summer! (or the best 5-à-7 day of the year!)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
