[mapserver-users] Building Mapserver with Memcachr Capability
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Mon Oct 29 00:54:43 PDT 2012
Seems to be a bug in the build system. When linking the test program
it instruct the linker to use a *.la file. Since you checked the
apr_memcache functions manually you can use the following workaround.
$ echo "ac_cv_lib_aprutil_1_apr_memcache_hash=yes" > config.cache
$ echo "ac_cv_header_apr_memcache_h=yes" >> config.cache
$ ./configure -C --enable-memcache=yes <your_other_switches>
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag
> von Wyatt Davis
> Gesendet: Donnerstag, 25. Oktober 2012 19:14
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Building Mapserver with Memcachr Capability
> Hello everyone,
> I am currently trying to build Mapcache from source with
> Memcache caching capabilities. The problem I am having is
> that when configuring Mapcache I receive this warning:
> configure: WARNING: supplied apr-util does not contain
> memcache functions. Memcache backend disable
> I have installed Apache and the apr and apu libraries through
> apt-get. I also tried on a separate machine building Apache,
> apr-1.4.6 and apu-1.4.1 from source with the same result.
> When I look inside of the apu static library it seems to have
> the memcache functions:
> $ nm libaprutil-1.a | grep memcache
> 000000000000a00 T apr_memcache_hash
> I am relatively new at this so it is quite possible I am
> making a simple, embarrassing mistake.
> If anyone has any suggestions I would be most grateful.
> Thank you,
> Wyatt
