[mapserver-users] vector Symbol and anchorpoint
thomas bonfort
thomas.bonfort at gmail.com
Sun Aug 11 05:56:11 PDT 2013
Andrea, the example I gave you does exactly that.
https://github.com/mapserver/msautotest/blob/master/renderers/line_anchorpoint.map#L20
, just remove the first style's COLOR if you don't want a fill.
thomas
On 11 August 2013 14:37, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi,
> Sorry, I forgot to explain my need.
> I need to define an outline of polygon with an perpendicular segment forward
> the internal of polygon.
> It goal is to allow to use only the outline (no internal fill) and also help
> the user to distinguish the internal and the external part of a polygon when
> the scale is bigger and the polygon is not all in the screen.
> The problem is that the symbol don't start exactly from the outpline but a
> little before.as it was moved.
> Andrea.
> 2013/8/11 thomas bonfort <thomas.bonfort at gmail.com>
>> As you're not showing what you would like to obtain, nor the mapfile
>> you are using to generate those images it is difficult to be of much
>> help. I have added a test in
>> https://github.com/mapserver/msautotest/commit/89d59a49586dc3192dfd2f67bd1a751f0900e36f
>> that mimics what I guess you would like to obtain, and for me shows
>> that anchorpoint seems to be working as expected.
>> thomas
>> On 11 August 2013 13:07, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > Hi,
>> > thx for response.
>> > I try to set this symbol:
>> > SYMBOL
>> > NAME "test"
>> > TYPE vector
>> > FILLED TRUE
>> > POINTS
>> > 0.0 0.0
>> > 1.0 0.0
>> > 0.5 0.0
>> > 0.5 0.5
>> > END
>> > ANCHORPOINT 0.0 0.0
>> > END
>> > But mapserver seem move the line by 0.5.
>> > I show in the attached image (img1) the problem.
>> > The filled green is the real polygon.
>> > Instead the red is the symbol I try to define with "test".
>> > As you can see the red line is not in the exact outline but 0.5 moved.
>> > I notice also that if I define this other kind of symbol:
>> > SYMBOL
>> > NAME "chiodo"
>> > TYPE vector
>> > FILLED TRUE
>> > POINTS
>> > 0.0 0.0
>> > 1.0 0.0
>> > 0.5 0.0
>> > # 0.5 0.5
>> > END
>> > ANCHORPOINT 0.0 0.0
>> > END
>> > Where I comment the perpendicul segment,
>> > the result is a red line exactly on the outline.
>> > I show this in the img2 attacched.
>> > So mapserver seem move the symbol when there is a perpendicular segment.
>> > Is this a bug or I don't understand how work the symbols ?
>> > Thx,
>> > Andrea.
>> >> try defining the points of your vector symbol such that min(x)=min(y)=0
>> >> On 11 August 2013 10:30, Andrea Peri <aperi2007 at gmail.com> wrote:
>> >> > Hi,
>> >> > I'm having trouble try.ing use the anchorpoint with a vector symbol.
>> >> > Is this working with vectors ?
>> >> > This is what I'm try to do:
>> >> > SYMBOL
>> >> > NAME "test"
>> >> > TYPE vector
>> >> > FILLED TRUE
>> >> > POINTS
>> >> > 0.5 1.0
>> >> > 0.5 0.75
>> >> > 0.0 0.75
>> >> > 1.0 0.75
>> >> > END
>> >> > ANCHORPOINT 0.0 0.0
>> >> > END
>> >> > The anchorpoint seem always set to the 0.5 0.5 position.
>> >> > I'm use the trunk version of mapserver.
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> >> > _______________________________________________
>> >> > mapserver-users mailing list
>> >> > mapserver-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> > Andrea Peri
>> > qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
