[mapserver-users] vector Symbol and anchorpoint
Andrea Peri
aperi2007 at gmail.com
Sun Aug 11 05:59:40 PDT 2013
Hi Thomas.
It work very well.
I tried to define a symbol with two segment: one perpendicolar to the other.
Instead more simple was to create an only one segment perpendicular to the
outline.
Many thx,
Andrea.
2013/8/11 thomas bonfort <thomas.bonfort at gmail.com>
> Andrea, the example I gave you does exactly that.
> https://github.com/mapserver/msautotest/blob/master/renderers/line_anchorpoint.map#L20
> , just remove the first style's COLOR if you don't want a fill.
> thomas
> On 11 August 2013 14:37, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > Sorry, I forgot to explain my need.
> > I need to define an outline of polygon with an perpendicular segment
> forward
> > the internal of polygon.
> > It goal is to allow to use only the outline (no internal fill) and also
> help
> > the user to distinguish the internal and the external part of a polygon
> when
> > the scale is bigger and the polygon is not all in the screen.
> > The problem is that the symbol don't start exactly from the outpline but
> a
> > little before.as it was moved.
> > Andrea.
> >> As you're not showing what you would like to obtain, nor the mapfile
> >> you are using to generate those images it is difficult to be of much
> >> help. I have added a test in
> https://github.com/mapserver/msautotest/commit/89d59a49586dc3192dfd2f67bd1a751f0900e36f
> >> that mimics what I guess you would like to obtain, and for me shows
> >> that anchorpoint seems to be working as expected.
> >> thomas
> >> On 11 August 2013 13:07, Andrea Peri <aperi2007 at gmail.com> wrote:
> >> > Hi,
> >> > thx for response.
> >> > I try to set this symbol:
> >> > SYMBOL
> >> > NAME "test"
> >> > TYPE vector
> >> > FILLED TRUE
> >> > POINTS
> >> > 0.0 0.0
> >> > 1.0 0.0
> >> > 0.5 0.0
> >> > 0.5 0.5
> >> > END
> >> > ANCHORPOINT 0.0 0.0
> >> > END
> >> > But mapserver seem move the line by 0.5.
> >> > I show in the attached image (img1) the problem.
> >> > The filled green is the real polygon.
> >> > Instead the red is the symbol I try to define with "test".
> >> > As you can see the red line is not in the exact outline but 0.5 moved.
> >> > I notice also that if I define this other kind of symbol:
> >> > SYMBOL
> >> > NAME "chiodo"
> >> > TYPE vector
> >> > FILLED TRUE
> >> > POINTS
> >> > 0.0 0.0
> >> > 1.0 0.0
> >> > 0.5 0.0
> >> > # 0.5 0.5
> >> > END
> >> > ANCHORPOINT 0.0 0.0
> >> > END
> >> > Where I comment the perpendicul segment,
> >> > the result is a red line exactly on the outline.
> >> > I show this in the img2 attacched.
> >> > So mapserver seem move the symbol when there is a perpendicular
> segment.
> >> > Is this a bug or I don't understand how work the symbols ?
> >> > Thx,
> >> > Andrea.
> >> >> try defining the points of your vector symbol such that
> min(x)=min(y)=0
> >> >> On 11 August 2013 10:30, Andrea Peri <aperi2007 at gmail.com> wrote:
> >> >> > Hi,
> >> >> > I'm having trouble try.ing use the anchorpoint with a vector
> symbol.
> >> >> > Is this working with vectors ?
> >> >> > This is what I'm try to do:
> >> >> > SYMBOL
> >> >> > NAME "test"
> >> >> > TYPE vector
> >> >> > FILLED TRUE
> >> >> > POINTS
> >> >> > 0.5 1.0
> >> >> > 0.5 0.75
> >> >> > 0.0 0.75
> >> >> > 1.0 0.75
> >> >> > END
> >> >> > ANCHORPOINT 0.0 0.0
> >> >> > END
> >> >> > The anchorpoint seem always set to the 0.5 0.5 position.
> >> >> > I'm use the trunk version of mapserver.
> >> >> > Andrea Peri
> >> >> > qwerty àèìòù
> >> >> > _______________________________________________
> >> >> > mapserver-users mailing list
> >> >> > mapserver-users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> > Andrea Peri
> >> > qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130811/21744894/attachment-0001.html>
