[mapserver-users] php mapscript 6.2.0 problem plotting TRANSFORM false rectobj
daryl herzmann
akrherz at iastate.edu
Fri Jan 25 13:03:00 PST 2013
The follow code worked for me with previous Mapserver releases, it
currently does not with PHP mapscript 6.2.0 on RHEL6 64bit. Any ideas
what I may be doing wrong? The result is a blank image and I expect to
see a black rectangle!
--> rect.map
MAP
NAME base4326
STATUS ON
SIZE 640 480
EXTENT -104 37 -87 49
UNITS DD
CONFIG "MS_ERRORFILE" "/tmp/ms_error.txt"
CONFIG "CPL_DEBUG" "ON"
DEBUG 5
LAYER
NAME rect
TYPE POLYGON
TRANSFORM FALSE
STATUS ON
LABELCACHE FALSE
CLASS
COLOR 0 0 0
END
END
END
---> rect.php
$map = ms_newMapObj('rect.map');
$img = $map->prepareImage();
$layer = $map->getLayerByName("rect");
$rect = ms_newRectObj();
$rect->setextent(100,100,200,200);
$rect->draw($map, $layer, $img, 0, "");
header("Content-type: image/png");
$img->saveImage('');
thanks,
daryl
