[mapserver-users] msWMSLoadGetMapParams(): Image handling error. Unsupported output format (image/png; bits=8)
Robert R. Raiz
raizrobert at gmail.com
Fri Jul 26 05:11:07 PDT 2013
Donald,
Thanks for the examples. The first one returns the same error, the second
one returns: loadOutputFormat(): General error message. OUTPUTFORMAT clause
references driver CAIRO/PNG, but this driver isn't configured;
It is odd, I thought that you don t even need to declare an outputformat.
I must say that I am using GeoMoose top view the map file, an I have and
extra section (compared to the ms5.0.0 version) which did not exist before
(do I even need it?):
WEB
METADATA
'ows_title' 'Parcel Maps'
'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
'ows_enable_request' '*'
'ows_onlineresource' 'http://www.geomoose.org'
END
END
I was thinking that maybe it has something to do with the OWS but if I
remove that part, again, it does not work.
On Fri, Jul 26, 2013 at 3:04 PM, Donald Kerr <donald.kerr at dkerr.co.uk>wrote:
> Robert,****
> I am using the following:****
> *OUTPUTFORMAT*
> * NAME "png"*
> * DRIVER "AGG/PNG"*
> * MIMETYPE "image/png"*
> * IMAGEMODE "RGBA"*
> * EXTENSION "png"*
> * FORMATOPTION "GAMMA=0.75"*
> * TRANSPARENT ON # Requires RGBA, not RGB otherwise errors. Also
> requires OFFSITE 255 255 255 in LAYER*
> *END*****
> Or, Using Cairo (though I still have some issues with labelling using this
> - https://github.com/mapserver/mapserver/issues/4581):****
> *OUTPUTFORMAT*
> * NAME "png"*
> * DRIVER "CAIRO/PNG"*
> * IMAGEMODE "RGBA"*
> * EXTENSION "png"*
> *END*
> Regards,****
> Donald****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Robert R. Raiz
> *Sent:* 26 July 2013 13:00
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] msWMSLoadGetMapParams(): Image handling
> error. Unsupported output format (image/png; bits=8)****
> Hello all,
> I've been using the following OUTPUTFORMAT with mapserver 6:****
> IMAGETYPE png****
> OUTPUTFORMAT****
> NAME "png8"****
> DRIVER AGG/PNG8****
> MIMETYPE "image/png; mode=8bit"****
> EXTENSION "png"****
> TRANSPARENT ON****
> IMAGEMODE RGBA****
> FORMATOPTION "QUANTIZE_FORCE=off"****
> FORMATOPTION "QUANTIZE_COLORS=256"****
> FORMATOPTION "INTERLACE=ON"****
> END****
> It works with vector data but it does a really bad job in rendering PIXMAP
> SYMBOLS, png files.
> No matter what other settings I tried in the OUTPUTFORMAT, I get the same
> error as stated in the subject field.
> I tried every example from the documentation but anything else than what I
> have above, gives me that error.
> Back in Mapserver5 I was using:****
> IMAGETYPE png24****
> OUTPUTFORMAT****
> NAME 'AGGA'****
> DRIVER 'AGG/PNG'****
> IMAGEMODE RGBA****
> MIMETYPE "image/png"****
> EXTENSION "png"****
> END ****
> It rendered everything ok but this does not work anymore as well.
> Can you help me out in trying to fix this as to display everything smooth?
> Thank you,****
> *Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130726/70253fd0/attachment-0001.html>
