[mapserver-users] Select the dataset at runtime
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Tue Jun 18 21:29:53 PDT 2013
Try this live example. The sql parameter is feeding a subquery into DATA and the next link selects OpenStreetMap primary highways which do not have maxpeed tag. Change primary into secondary and you will see a different map.
http://hip.latuviitta.org/cgi-bin/ms_ows?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=563&HEIGHT=437&LAYERS=sea,borders,osm_viivat&TRANSPARENT=TRUE&FORMAT=image/png&BBOX=-369151.98300283286,6597900.0,1511076.628895184,8057331.444759207&SRS=EPSG:3067&STYLES=&sql=(tags @> 'highway=>primary') AND not (tags ? 'maxspeed') <http://hip.latuviitta.org/cgi-bin/ms_ows?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=563&HEIGHT=437&LAYERS=sea,borders,osm_viivat&TRANSPARENT=TRUE&FORMAT=image/png&BBOX=-369151.98300283286,6597900.0,1511076.628895184,8057331.444759207&SRS=EPSG:3067&STYLES=&sql=%28tags%20@%3E%20%27highway=%3Eprimary%27%29%20AND%20not%20%28tags%20?%20%27maxspeed%27%29%20>
-Jukka Rahkonen-
Andrea Peri wrote:
thx for response.
I see the example. Its pretty interesting.
Also another option I found in the documentation:
http://mapserver.org/cgi/runsub.html
I see in the MS6.2 should be possible to act on
DATA and DATAPATTERN.
I guess this could be a good choice, but no other information on this and how to use.
Is this runtime substitution for DATA and DATAPATTERN really available ?
Thx,
2013/6/18 Kralidis,Tom [Ontario] <Tom.Kralidis at ec.gc.ca<mailto:Tom.Kralidis at ec.gc.ca>>
Andrea: you can do something like use runtime substitution (neat example at http://linfiniti.com/2011/09/making-the-most-of-umn-mapserver-runtime-variable-substitution/), or MapScript WxS wrappers (http://mapserver.org/ogc/mapscript.html#python-examples).
From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Andrea Peri
Sent: June 18, 2013 2:27 PM
To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Select the dataset at runtime
Is possible to change at runtime the datasource of a layer using a parameter of the request to choose the dataset ?
I'm explain better.
I have two datasource of the same physical phenomenon.
The first is at 96dpi and the second at 300dpi.
I like to show the first when the user see it on a webgis and ask it using a request getmap with the extra parameter map_resolution=96
Instead the mapserver should return the second dataset when the request has an extra_parameter map_resolution=300 tipically when the user call it for a print at high resolution.
I'm trying to avoid to set two distinct mapserver layers.
To avoid the user should change the layer in the request.
The solution I'm searching is to allow the use of the parameter "map_resolution" to choose the dataset to use.
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
