[mapserver-users] Generating the Map-file on Windows
Andrey Maraev
asmaraev at gmail.com
Wed Jun 19 06:14:46 PDT 2013
Hello! I try to generate the mapfile on Windows according to the
instruction:
https://github.com/mapserver/mapserver/wiki/RenderingOsmDataWindows
When I make step 9 manually via cygwin it works. But I have a question: Did
anyone use it via scripts? I tried to write cmd-script but have a problems
with a make`s adaptation.
If I use:
@echo off
SET PATH=%PATH%;"C:\cygwin\bin"
make all
:EOF
I get the errors with make
sed -i 's/##.*$//g' osm-default.map
make: sed: Command not found
Makefile:105: recipe for target `osm-default.map' failed
make: *** [osm-default.map] Error 127
Could you please give an advices how fix it or is there other ways how to
change makefile script or use something different, not the make?
Best regards
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130619/614b3317/attachment.html>
