[mapserver-users] Mapserver 6.2 on RHEL
Stephan Meißl
stephan at meissl.name
Fri May 31 03:38:19 PDT 2013
Hi Jeff,
I'm using this spec file [1] including the configure parameters. Please
send a pull request if you find something missing.
Thanks,
Stephan
[1] https://github.com/mapserver/packaging/blob/master/el/mapserver.spec
On 05/30/2013 11:08 PM, Jeff Konnen wrote:
> Hi Stephan,
> install worked like a charm. We've got one problem though "SVG symbol support is not enabled".
> I don't know if it is a problem of your package or a more general problem with mapserver 6.2.0?
> I guess I'll have to compile it nevertheless :(
> Thanks
> Jeff
> On 29 May 2013, at 13:21, Stephan Meißl <stephan at meissl.name> wrote:
>> On 05/28/2013 11:28 PM, Jeff Konnen wrote:
>>> Hi all,
>>> before going down the compile path, I just want to make sure I didn't miss something.
>>> I need to install mapserver 6.2 on RHEL 6.4 and was looking for a repository or a rpm.
>>> but I couldn't find anything.
>>> Is there something out there that I could have missed?
>>> Thanks a lot in advance
>>> Jeff
>> Hi Jeff,
>> we're hosting an EL 6 yum repository including MapServer 6.2 builds at
>> http://packages.eox.at/ The packages are generated on CentOS hosts but
>> should work on RHEL. If you give it a try I'd be interested to hear your
>> experience.
>> cu
>> Stephan
