[mapserver-users] MapCahe question -- Caching the first couple of zoom levels
Rahkonen Jukka
jukka.rahkonen at mmmtike.fi
Sun Nov 24 09:33:16 PST 2013
GeoWebCache supports this as "Selective zoom level caching"
http://geowebcache.org/docs/current/configuration/layers/selectivezoom.html
MapProxy seems to be able to do the same with directives "use_direct_from_level" and "use_direct_from_res"
http://mapproxy.org/docs/1.6.0/configuration.html
I guess that Mapcache will also support this practical feature sooner or later.
-Jukka Rahkonen-
________________________________________
Stephen Woodbridge wrote:
> On 11/24/2013 10:57 AM, James_in_Utah wrote:
>> Hi,
>> I'm trying to configure mapcache (from latest dev version of MS4W) and would
>> like to cache the first couple of zoom levels of a very large set of USDA
>> NAIP imagery. I've tried using the minzoom and maxzoom tags in the tileset,
>> like this:
>> <grid restricted_extent="-180 -90 180 90" minzoom="1"
>> maxzoom="6">WGS84</grid>
>> but once I zoom below the maxzoom value I get no imagery. I would like it
>> to send the request to the source if it is beyond the maxzoom value. Is
>> there a way to do this?
>> Thanks,
>> James
> James,
> If I understand you question correctly:
> You want mapcache to cache only zoom levels 1-6 and then handoff all
> requests for zoom levels 7+ to the WMS to draw on demand.
> Is this correct?
> If so, I'm not sure that mapcache can to that, you may have to do that
> in your client software where it has two layers: one for the mapcache
> zoom levels and then another for the WMS requests.
> The minzoom and maxzoom parameters control whether or not mapcache will
> serve responses with data.
> -Steve W
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
