[mapserver-users] Mapserver shows all nodes on a GeometryCollection
Jörg Thomsen
jt at mapmedia.de
Tue Apr 15 07:20:19 PDT 2014
hm..
- lines and points are stored in the same table you said?
- do you get the correct result if you do the data-query in postgis /
pgadmin?
- what happens if you use your point-shape-file as data-source in mapserver?
- if you only request the line-layer the points don't appear?
- could you post the whole mapfile?
Jörg
Am 15.04.2014 13:50, schrieb drobins:
> Let my add a screenshot from my problem
> <http://osgeo-org.1560.x6.nabble.com/file/n5135121/error.png>
> I have 2 layers enabled in my map: a point layer and a line layer.
> The line layer works correct.
> The point layer shows points that are not in my source data (shape file
> which I inserted into postgis).
> At every end of a line, somehow a point is added, which isn't in my source
> data.
> When I load the same area in QGIS, these points do not appear.
> I hope this makes my problem more clear.
> Thanks
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapserver-shows-all-nodes-on-a-GeometryCollection-tp5135064p5135121.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
