[mapserver-users] A crash due to a space on front of a 'select' is an issue ?
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Jul 6 07:33:43 PDT 2014
Even,
Thank you for looking into this. Looks like it is appropriately trapping
the error and reporting it. Maybe a ticket asking for more tolerance as
you suggest would be appropriate.
Thanks,
-Steve W
On 7/6/2014 9:40 AM, Even Rouault wrote:
> Le dimanche 06 juillet 2014 10:21:10, Andrea Peri a écrit :
>> Hi,
>> I notice that when , in the mapfile,
>> I define a DATA element
>> like this:
>> DATA " select field1, field2, field3 from TABLE1"
>> notice the space before the 'select' declaration.
>> The mapserver crash declaring to be unable to reach the data.
> Is the declaration of being unable to reach the data is something like the
> following ?
> <?xml version='1.0' encoding="UTF-8" ?>
> <ServiceExceptionReport version="1.2.0" xmlns="http://www.opengis.net/ogc"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="http://www.opengis.net/ogc
> http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
> <ServiceException code="NoApplicableCode" locator="mapserv">
> msWFSGetFeature: WFS server error. FLTApplyFilterToLayer() failed
> msOGRFileOpen(): OGR error. GetLayer( SELECT NAME,UNIQUE_KEY,CAPITAL,POP_RANGE
> FROM popplace) failed for OGR connection `data/popplace.shp'.
> </ServiceException>
> </ServiceExceptionReport>
> If so, that's OK I guess. We could be more tolerant with leading spaces, but
> this isn't a crash, but an error message which gives some hint on where things
> are wrong.
>> The issue is the space in front of the select.
>> I don't know if this happened with all the formats.
>> Surely it happen with spatialite format (I use it).
>> I don't know if this is an issue to report or simply a wrong use of
>> data element.
>> Regards,
>> A
