[mapserver-users] PHP Mapscript Line Width Drawing Issue
Brian Walawender - NOAA Federal
brian.walawender at noaa.gov
Fri Jun 6 07:10:35 PDT 2014
Hello,
I'm having an occasional php mapscript issue where lines with a width
greater than 1 are not being filled. If I set the width to 1 one the issue
does not occur. The link below shows two cases of this happening.
http://www.crh.noaa.gov/images/crh/line_width_issue.png
The example in the lower part of the image is TIGER state data drawn from
PostGIS:
LAYER
NAME "state"
METADATA
"wms_title" "state"
END
PROJECTION
"init=epsg:4269"
END
STATUS ON
CONNECTIONTYPE postgis
INCLUDE 'connection.info'
TYPE POLYGON
DATA "geom FROM data.tiger_state AS SUBQUERY USING UNIQUE gid USING
SRID=4269"
CLASS
STYLE
WIDTH 2
OUTLINECOLOR 0 0 0
END
END
PROCESSING "CLOSE_CONNECTION=NORMAL"
END
The example on the right hand side of the image is a linestring:
LAYER
NAME "line"
METADATA
"wms_title" "line"
END
PROJECTION
"init=epsg:4269"
END
STATUS ON
TYPE LINE
DATA "geom FROM (SELECT 1 AS id, ST_GeomFromText('LINESTRING(-96 38, 97
37)') AS geom) AS SUBQUERY USING UNIQUE id USING SRID=4269"
CLASS
STYLE
COLOR 0 0 0
WIDTH 3
END
STYLE
GEOMTRANSFORM 'end'
ANGLE AUTO
SYMBOL 'arrow'
SIZE 22
COLOR 0 0 0
END
END
END
I'm running mapserver 6.4.1 with PHP 5.3.3
MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=GEOS
INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Thanks.
bw
Brian Walawender
IT Branch Chief
Systems and Facilities Division
NOAA/National Weather Service
Central Region Headquarters
816-268-3114 - Office
816-805-6497 - Cell
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140606/e73e0cda/attachment.html>
