[mapserver-users] Why $map->scaledenom returns -1 ?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Mon Jun 16 08:43:17 PDT 2014
Scale can only be computed if there is a map extent and map size set. Are you doing so?
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Vladimir
Sent: Monday, June 16, 2014 1:12 AM
To: mapserver-users
Subject: [mapserver-users] Why $map->scaledenom returns -1 ?
Hello list
I stuck on the scaledenom definition in my PHPMapScript v. 6.4.1.
The current scaledenom required to embed in SQL-statement, but
$map->scaledenom returns -1. Tons of googling got nothing. Please help!
phpscript.php ---------------------------------------------------------------------------------------------
$map = ms_newMapobj("/srv/www/htdocs/tez/design/mapfile.map");
$request = ms_newOwsrequestObj();
if(!empty($_GET)){
foreach ($_GET as $key => $value) {
$request->setparameter($key, $value);
$map->preparequery();
$map->scaledenom;//returns -1
$rayonLayer = $map->getLayerByName("rayon");
$rayonLayer->set("data","geom from (select id, name, geom from location
where ST_Intersects(geom, !BOX!)) as subquery using unique id using srid=3857");
ms_ioinstallstdouttobuffer();
$map->owsDispatch($request);
$contenttype = ms_iostripstdoutbuffercontenttype();
header('Content-type:'.$contenttype);
ms_iogetStdoutBufferBytes();
ms_ioresethandlers();
mapfile.map---------------------------------------------------------------------------------------------
MAP
NAME "Map"
OUTPUTFORMAT
NAME 'AGG'
DRIVER AGG/PNG
IMAGEMODE RGB
END #OUTPUTFORMAT
STATUS ON
FONTSET "fonts/fonts.list"
CONFIG "PROJ_LIB" "/usr/lib/proj/"
WEB
METADATA
wms_title "Map"
wms_abstract "Map"
wms_onlineresource "http://localhost/phpscript.php"
wms_srs "EPSG:3857"
wms_enable_request "*"
wms_encoding "utf-8"
END # end METADATA
END # end WEB
PROJECTION
"init=epsg:3857"
END # end PROJECTION
LAYER
NAME "rayon"
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=ms_viewer password=1 dbname=ms_db host=localhost"
TYPE POLYGON
LABELITEM "name"
CLASS
NAME "rayons"
STYLE
OUTLINECOLOR 255 0 0
OUTLINEWIDTH 5
END # end STYLE
END # end CLASS
PROJECTION
"init=epsg:3857"
METADATA
wms_title "rayon"
wms_abstract "rayon"
wms_srs "EPSG:3857"
wms_include_items "all"
END # end METADATA
END # end LAYER
END # end MAP
Best regards
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140616/c26cd57f/attachment-0001.html>
