[mapserver-users] [EXTERNAL] Layer with point from X and Y columns in
Jakub Štambachr
stambikk at gmail.com
Thu Mar 13 05:05:32 PDT 2014
Mike,
thank you for your help, works like a charm.
Jakub
From: Smith, Michael ERDC-RDE-CRREL-NH [mailto:Michael.Smith at erdc.dren.mil]
Sent: Thursday, March 13, 2014 12:01 PM
To: Jakub Štambachr; mapserver-users at lists.osgeo.org
Subject: Re: [EXTERNAL] [mapserver-users] Layer with point from X and Y
columns in
Jakub,
What you have to do is disable the use of the spatial index (since you are
defining this on the fly, there will be no index).
DATA "shape FROM (select MDSYS.SDO_GEOMETRY(2001, NULL,
MDSYS.SDO_POINT_TYPE(table.x, table.Y, NULL), NULL, NULL) AS shape from
table)" USING NONE
See <http://mapserver.org/input/vector/oracle.html#using-none>
http://mapserver.org/input/vector/oracle.html#using-none for details.
Mike
Michael Smith
US Army Corps
Remote Sensing GIS/Center
Date: Thursday, March 13, 2014 at 5:39 AM
To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Subject: [EXTERNAL] [mapserver-users] Layer with point from X and Y columns
in
Resent-From: Michael Smith <michael.smith at usace.army.mil>
I have table in Oracle Database that contains points specified by columns X
and Y (The table also contains SDO_Geometry column but it's not always
filled with data and I'm not at liberty to modify the table).
My question is: Is it possible to specify layers with point using the
columns X and Y?
So far I have something like this and I need an alternative to replace the
DATA
TYPE POINT
CONNECTIONTYPE oraclespatial
CONNECTION "isypoo/password at orcl"
DATA "shape FROM (select table.shape as SHAPE from table)"
I tried the following:
table)"
But got the following error:
msDrawMap(): Image handling error. Failed to draw layer named 'mosty'.
msOracleSpatialLayerWhichShapes(): OracleSpatial error. Error: ORA-13226:
interface not supported without a spatial index
Is there any other way of doing this without modifying the database?
Thank you for your help,
Jakub
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140313/b66cd402/attachment-0001.html>
