[mapserver-users] Install MapCache
Mathieu Coudert
mathieu.coudert at gmail.com
Tue Nov 25 13:55:06 PST 2014
I guess you're compiling MapCache on Debian Wheezy?
It seems to be a known issue on Debian which had been fixed, except for
Wheezy!
But as they mention in the issue, the problem is noisy but harmless...So
you can ignore it.
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=707109
Cheers,
Mathieu
On Thu, Nov 6, 2014 at 7:13 AM, <scott159 at free.fr> wrote:
> I'm trying to install the mapcache. I've downloaded the zip file from
> github but i got an error when i was installing :
> -- The C compiler identification is GNU 4.7.2
> -- The CXX compiler identification is GNU 4.7.2
> -- Check for working C compiler: /usr/bin/gcc
> -- Check for working C compiler: /usr/bin/gcc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Looking for strncasecmp
> -- Looking for strncasecmp - found
> -- Looking for symlink
> -- Looking for symlink - found
> -- Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version "1.2.7")
> -- Found PNG: /usr/lib/x86_64-linux-gnu/libpng.so (found version "1.2.49")
> -- Found JPEG: /usr/lib/x86_64-linux-gnu/libjpeg.so
> -- Found CURL: /usr/lib/x86_64-linux-gnu/libcurl.so (found version
> "7.26.0")
> -- Found APR: /usr/lib/libapr-1.so
> -- Found APU: /usr/lib/libaprutil-1.so
> -- Looking for apr_memcache_hash
> -- Looking for apr_memcache_hash - found
> -- Found PkgConfig: /usr/bin/pkg-config (found version "0.26")
> -- checking for module 'pixman'
> -- package 'pixman' not found
> -- checking for module 'pixman-1'
> -- found pixman-1, version 0.26.0
> -- Found PIXMAN: /usr/lib/x86_64-linux-gnu/libpixman-1.so
> -- Found PCRE: /usr/lib/x86_64-linux-gnu/libpcre.so
> -- Found SQLITE: /usr/lib/x86_64-linux-gnu/libsqlite3.so
> -- Found TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so (found version "3.9.6")
> -- * Configured options for the mapcache library
> -- * Mandatory components
> -- * png: /usr/lib/x86_64-linux-gnu/libpng.so
> -- * jpeg: /usr/lib/x86_64-linux-gnu/libjpeg.so
> -- * Curl: /usr/lib/x86_64-linux-gnu/libcurl.so
> -- * Apr: /usr/lib/libapr-1.so
> -- * Optional components
> -- * PIXMAN: /usr/lib/x86_64-linux-gnu/libpixman-1.so
> -- * SQLITE: /usr/lib/x86_64-linux-gnu/libsqlite3.so
> -- * Berkeley DB: disabled
> -- * Memcache: /usr/lib/libaprutil-1.so
> -- * TIFF: /usr/lib/x86_64-linux-gnu/libtiff.so
> -- * GeoTIFF: disabled
> -- * Experimental TIFF write support: disabled
> -- * PCRE: /usr/lib/x86_64-linux-gnu/libpcre.so
> -- * Experimental mapserver support: disabled
> -- Found GDAL: /usr/lib/libgdal.so
> -- Found GEOS: /usr/lib/libgeos_c.so
> -- * Seeder Configuration Options:
> -- * GEOS: /usr/lib/libgeos_c.so
> -- * OGR: /usr/lib/libgdal.so
> -- Found FCGI: /usr/lib/libfcgi.so
> -- * CGI Configuration Options:
> -- * FastCGI: /usr/lib/libfcgi.so
> -- Found APACHE: /usr/include/apache2
> -- * Apache Module support status:
> -- * Mapcache Version String: mod_mapcache/1.2.1
> -- * Module will be installed to : Use of uninitialized value
> $includedir in concatenation (.) or string at (eval 9) line 1.
> /usr/lib/apache2/modules
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /var/www/mapcache-1-2-1/build
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141125/ed7a0452/attachment.html>
