[mapserver-users] Runtime variable Substitution Filter
milad nidal
miladnidal2604 at gmail.com
Fri Mar 11 05:31:37 PST 2016
Could you please explain more about how to do it (the first time which I'm
using this variable)..
Do you mean that I use ‘default_nom’ ‘ aaa’ in the layer metadata (it
does not work).. where I should put the default value?
Thanks
On Thu, Mar 10, 2016 at 11:06 PM, Richard Greenwood <
richard.greenwood at gmail.com> wrote:
> Michael's suggestion is very good. Another method would be to define the
> later twice with two different names and no filter in one of the
> definitions. That would also allow you to style the layer differently which
> might be desirable.
> Rich
> On Thu, Mar 10, 2016 at 6:44 PM, Michael Smith <
> michael.smith.erdc at gmail.com> wrote:
>> You can set a default value for your layer when no value is set. What I
>> do is set it to something like 1=1 and then all values will display.
>> http://mapserver.org/cgi/runsub.html#default-values-if-not-provided-in-the-url
>> Michael Smith
>> Remote Sensing/GIS Center
>> US Army Corps of Engineers
>> On Mar 10, 2016, at 8:36 PM, milad nidal <miladnidal2604 at gmail.com>
>> wrote:
>> Hi,
>> I'm using Runtime variable Substitution (FILTER "nom in (
>> %municipalitylist% )") to chose one municipality from a list and it is
>> going good. But how I can visualize all the municipalities in the layer?
>> Is-it possible to ignore the filter?
>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Richard W. Greenwood, PLS
> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160311/b98e8559/attachment-0001.html>
