[mapserver-users] KML output 6.4.2
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Oct 19 05:41:33 PDT 2016
Great, keep us all in the loop with how it goes.
You'll find that using the WFS outputformat for KML/KMZ works very well,
as it is passed through the OGR driver; I'm not aware of many using WMS
for KML/KMZ output. But yes, I imagine if you travel down that path you
may eventually hit my same issue from 2011 :)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-10-19 9:29 AM, Moisan, Yves (EC) wrote:
> Hi Jeff,
> Thanx for the info. There may be something missing in the mapfile, I'll double check.
> WFS is not an option for me. I need a <NetworkLink> element that points to a GetMap request for each layer.
> Cheers,
> Yves
> -----Message d'origine-----
> De : mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] De la part de Jeff McKenna
> Envoyé : 18 October 2016 6:13
> À : mapserver-users at lists.osgeo.org
> Objet : Re: [mapserver-users] KML output 6.4.2
> I have been more successful with KML output through WFS, by setting an OUTPUTFORMAT block in your mapfile and then passing &outputformat=kml in your WFS request. Is that an option for you??
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services http://www.gatewaygeomatics.com/
> On 2016-10-18 5:45 PM, Moisan, Yves (EC) wrote:
>> Hi All,
>> Haven’t been here in a while … I’m striving to find out how to either
>> query MS or run a command to generate a KML document ready to be
>> ingested by Google Earth. I’ve seen the documentation mentioning
>> “Output can then be generated using MapServer cgi (example mode=map) or
>> through a WMS request.” [1] and I understand the capability has been
>> there since 6.0, but I can’t get around to obtaining a KML document that
>> has <NetworkLink> elements pointing to the GetMap requests of particular
>> layers. I do get KML documents (with FORMAT=kml), but they miss a
>> <NetworkLink> element in the <Folder> element corresponding to a layer
>> from which GE could fetch an image :
>> <Folder>
>> <name>MyName</name>
>> <visibility>1</visibility>
>> <styleUrl>#LayerFolder_check</styleUrl>
>> <!-- NetworkLink> MISSING </NetworkLink -->
>> </Folder>
>> Examples or pointers anyone ?
>> TIA,
>> Yves
>> [1] http://mapserver.org/output/kml_output.html
