[mapserver-users] Define an End-Time attribute in WMS Time
Andrea Peri
aperi2007 at gmail.com
Sun Feb 26 23:26:43 PST 2017
I see it.
You have right infact I could define something like:
wms_dimensionlist: = start_date, end_date
wms_start_date_item= time
wms_end_date_item= time
wms_start_date_extent= "1900/01/01"
wms_end_date_extent= "2999/01/01"
wms_start_date_default=current
wms_end_date_default=current
This could be a solution on wms server side, but on client side it
need to have a wms client able to understant wms-dimension.
Actually my client interface is able to recognize and use a wms-time
but not able to recognize and use correctly a wms-dimensional from
getcapabilities.
A.
2017-02-27 7:48 GMT+01:00 Emanuele Di Giacomo <edigiacomo at arpae.it>:
> Hi Andrea,
> if you need two datetime attributes for each feature (in your example,
> for each county), you can use custom dimensions
> http://mapserver.org/ogc/wms_dimension.html.
> Emanuele
> On Sun, Feb 26, 2017 at 6:32 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi Jeff.
>> I was understanding the wms_timeextend as defined in the annex C3 of OGC.
>> AFAIK it is the domains of availability for the values in the
>> time-field in all the dataset
>> But is always one only attribute. This is ok for spot events. Instead
>> when there is a dataset where every feature is a start-date and an
>> end-date of validity for every single feature of dataset.
>> As example:
>> the dataset of county boundaries. Sometime the county bounaries could
>> change so they have a startdate and an enddate.
>> So is need to define both: the end-date and the start-date using two
>> attribute fields.
>> I wrong to understand the wms_timeextend ?
>> Thx,
>> A.
>> 2017-02-26 17:29 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
>>> Hi Andrea,
>>> The possible WMS Time parameters for MapServer are documented at:
>>> http://mapserver.org/ogc/wms_time.html There is a "wms_timeextent"
>>> parameter that sets the possible start/end time range, but I am not sure if
>>> I am understanding your question fully.
>>> -jeff
>>> Jeff McKenna
>>> MapServer Consulting and Training Services
>>> http://www.gatewaygeomatics.com/
>>> On 2017-02-26 11:58 AM, Andrea Peri wrote:
>>>> Hi,
>>>> I need to define a WMS Time for using on an our dataset.
>>>> But I need colud define also a End-Time attribute. Because a single
>>>> feature has a
>>>> start-time validity and an end-time validity.
>>>> Searching for some workaround on internet, I see that this option
>>>> (start-time and end-time of validity for a feature) is allowed in
>>>> geoserver.
>>>> http://docs.geoserver.org/latest/en/user/data/webadmin/layers.html#data-webadmin-layers-edit-dimensions
>>>> So I hope it could be done also possible in mapserver.
>>>> Thx.
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Andrea Peri
>> qwerty àèìòù
Andrea Peri
qwerty àèìòù
