[mapserver-users] Info Template
Steve Lime
sdlime at gmail.com
Wed Nov 20 08:59:17 PST 2019
For the sake of completeness, "$value" is the default format and doesn't
need to be explicitly set. --Steve
On Wed, Nov 20, 2019 at 7:29 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi Markus,
> I am not sure if you’d prefer me to answer in Finnish but English is
> easier for the majority of readers.
> Certainly it is possible to use data from a database with templates yes
> but you did not tell the details about for what purpose you are trying to
> use the templates. The DATA (perhaps with CONNECTION) that is used in LAYER
> https://mapserver.org/mapfile/layer.html can also be used as a data
> source for templates.
> An example from an old mail
> http://osgeo-org.1560.x6.nabble.com/html-tags-in-GetFeatureInfo-td5224781.html
> contains a template that defines the html format of GetFeatureInfo. Each
> “item name” is a name of the attribute in the source data. If vector data
> for the LAYER comes from MYSQL then the attributes are read from MYSQL as
> well.
> <body>
> <h3>NIMI</h3>
> [item name=NIMI format="$value" escape=none]
> <h3>LISÄTIEDOT</h3>
> [item name=KIELLONLISATIETO format="$value" escape=none]
> <h3>VOIMASSAOLO</h3>
> [item name=VOIMASSAOLO format="$value" escape=none]
> <h3>YHTEYSTIEDOT</h3>
> [item name=YHTEYSTIEDOT format="$value" escape=none]
> </body>
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> *Puolesta
> *Markus Lütke Brintrup
> *Lähetetty:* keskiviikko 20. marraskuuta 2019 14.53
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> *Aihe:* [mapserver-users] Info Template
> Hallo Liste,
> besteht die Möglichkeit in der Template.html eines Map-Projektes eine
> Datenbankanbindung an zu steuern?
> Beispiel:
> <tr>
> <td><b>Projektname:</b></td>
> <td>[Werte aus MYSQL-DB]</td>
> </tr>
> Freundliche Grüße
> WipflerPLAN
> Niederlassung Donauries
> Telefon: 09081 27509-44
> Telefax: 09081 27509-50
> mlb at wipflerplan.de
> *www.wipflerplan.de <http://www.wipflerplan.de/>*
> WipflerPLAN Planungsgesellschaft mbH
> Standort Nördlingen
> An der Lach 11a
> 86720 Nördlingen
> Amtsgericht Ingolstadt HRB 190595
> Geschäftsführer:
> Wilhelm Wipfler
> Ursula Burkart
> Adelheid Buchard
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20191120/b769957e/attachment-0001.html>
