[mapserver-users] Mapcache : Incompatible libpng version in application and library
Steve Lime
sdlime at gmail.com
Fri Feb 28 09:38:38 PST 2020
I'd think you must multiple libpng installed. Did you search your system
independent of the package manager?
On Wed, Feb 26, 2020 at 4:12 AM Johannes Paul <johannespaul92 at gmail.com>
wrote:
> Hello,
> I've compiled Mapcache from source, and the installation worked just fine,
> without any error, however when I run mapcache_seed, I get the following
> error :
> libpng warning: Application was compiled with png.h from libpng-1.5.13
> libpng warning: Application is running with png.c from libpng-1.2.56
> libpng error: Incompatible libpng version in application and library
> Mapcache has been compiled correctly using libpng 1.5.13, however I don't
> understand why mapcache_seed is trying to run with libpng 1.2.56 which is
> not even installed !
> Any idea ?
> Thanks,
> Johannes
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20200228/ae33105e/attachment.html>
