[mapserver-users] Mapcache : Incompatible libpng version in application and library
Even Rouault
even.rouault at spatialys.com
Fri Feb 28 09:48:53 PST 2020
On vendredi 28 février 2020 11:38:38 CET Steve Lime wrote:
> I'd think you must multiple libpng installed. Did you search your system
> independent of the package manager?
libpng-1.2.56 rings a bell to me. This is copy of libpng that is embedded in
GDAL source tree. So you'd better make sure that your GDAL is built against
system libpng, instead of the internal copy.
Even
http://www.spatialys.com
