[mapserver-users] Raster Upsampling
Patrick Young
patrick.mckendree.young at gmail.com
Fri Sep 10 09:17:21 PDT 2021
Hello!
I was curious if it is possible to have mapserver bilinearly upsample a low
resolution raster to a higher resolution when there is no reprojection
required.
My setup is that I have a very low resolution image (a bathymetric layer)
and a much higher resolution image (aerial), both in web mercator. When I
request a high resolution XYZ tile, the low resolution image remains
pixelated (it looks as if its is nearest neighbor upsampled) at the
raster's native resolution even though I have set in the PROCESSING
directive RESAMPLE=BILINEAR.
I suspect from the docs that RESAMPLE only comes into play when we're doing
on-the-fly reprojection, is that correct? When no reprojection is
required, but just simpler upsampling, can one change the kernel used?
Many thanks!
Patrick
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210910/854cbdef/attachment.html>
More information about the MapServer-users
