[MapServer-users] Swig Mapscript Still Fails to Build with PHP 8
b g
mapserverlearn at outlook.com
Wed Sep 28 08:48:31 PDT 2022
Hi Jeff,
Thanks for your response. It was indeed helpful and gave me something to try out. However, when I try those lines of code, this is what it says:
Looking for PCRE2 tarball...
ls: pcre2-*.tar*: No such file or directory
Could not find tarball matching pattern: pcre2-*.tar*
admin at Administrators-Mac swig-git-master % ./autogen.sh
+ test -d Tools/config
+ aclocal -I Tools/config
./autogen.sh: line 11: aclocal: command not found
admin at Administrators-Mac swig-git-master % ./configure --prefix=/usr
zsh: no such file or directory: ./configure
admin at Administrators-Mac swig-git-master % make
make: *** No targets specified and no makefile found. Stop.
Are there any other lines that I need to include with those? The first few run just fine (although I needed to replace 'wget' with 'curl'). And does this replace the use of the Github clone for MapServer 8.0? Or is this supposed to be setup in conjunction with MapServer 8.0?
Thanks again for your help,
bg
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> on behalf of Jeff McKenna <jmckenna at gatewaygeomatics.com>
Sent: Tuesday, September 27, 2022 6:11 PM
To: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Swig Mapscript Still Fails to Build with PHP 8
Hi BG,
Thanks for starting this discussion here, as many other readers will
help & learn from your situation; I first want to wish you a warm
welcome from the MapServer community :)
As Seth mentioned, I spent a lot of effort setting up the automated PHP
8 + MapServer 8 builds "on the cloud", and some of those steps can be
used by you directly.
But to step back a bit, first thing to mention is that PHP 8 with
MapServer 8 is best handled through the SWIG library "master" branch,
and this is likely one of your issues (the Homebrew formula you are
using for SWIG is probably SWIG 4.0.x, and you need the upcoming 4.1.0
release, or build its master branch from source).
Regarding the SWIG 4.1.0 upcoming release (and its heavy demand), see my
call for help at
https://lists.osgeo.org/pipermail/mapserver-dev/2022-September/016881.html
Regarding you possibly compiling SWIG 'master' branch, you can follow my
exact steps to do this on these lines:
https://github.com/MapServer/MapServer/blob/main/ci/travis/before_install.sh#L38-L47
(maybe other Mac devs can update those steps here in this discussion
thread for you)
I personally think all this will take some time before all packagers
catch up to these changes, to make it smooth for their users. In this
case some time is required before the next SWIG can be released, and
then propagated to all those FOSS4G packages that we love.
Its for this exact reason that I have put almost my entire career into
MS4W, to prevent users from facing these same build challenges (and
there are many challenges, ha).
I'm not sure that I've helped with this response, other than giving you
some background info.
Don't be discouraged, you will indeed fall in love with MapServer :)
Thanks,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220928/1029b8f9/attachment-0001.htm>
More information about the MapServer-users
