[MapServer-users] Inconsistent support for template substitution
Andrew Harfoot ajph at geodata.soton.ac.uk
Thu Oct 19 09:11:29 PDT 2023
Hi Seth,
Thanks for checking that, I see what you mean. I'll submit a pull
request to correct the logic.
Cheers,
Andy
On 19/10/2023 16:26, Seth G wrote:
> *CAUTION:* This e-mail originated outside the University of Southampton.
> Hi,
> This seems like a bug - there is a check to see if the Map projection
> is a geographic coordinate system [1], and if it is then it skips all
> the [maplon], [maplat], [minlon] etc. substitutions. If it is in
> another projection then the point and extent are reprojected to latlon
> and included in the template.
> Seth
> [1]
> https://github.com/MapServer/MapServer/blob/main/src/maptemplate.c#L4273
> web:https://geographika.net & https://mapserverstudio.net
> twitter: @geographika
> On Thu, Oct 19, 2023, at 3:50 PM, Andrew Harfoot via MapServer-users
> wrote:
>> Hi list,
>> I am setting up a WMS server using Mapserver 7.6.2 and want to return
>> a html response to a GetFeatureInfo request where the response
>> contains the coordinates of the GFI click. The WMS supports multiple
>> coordinate systems, so ideally I'd like to have the coordinates in a
>> CRS that I can predetermine.
>> I have a test template file as follows:
>> <!-- MapServer Template -->
>> <p>
>> Map X/Y : [mapx],[mapy]<br>
>> Map LL : [maplon],[maplat]
>> </p>
>> If I configure an 'old style' TEMPLATE in the map file, directly
>> referencing the html template as follows:
>> LAYER
>>    TEMPLATE "coord_comp.html"
>> With a GFI request specifying a CRS of EPSG:27700:
>> ...&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetFeatureInfo
>>    &BBOX=379766.9556955648586154,58602.32640402266406454,405538.15569556411355734,94300.79913129436317831
>>    &CRS=EPSG:27700&WIDTH=649&HEIGHT=899&LAYERS=test&STYLES=&FORMAT=image/jpeg&QUERY_LAYERS=test
>>    &INFO_FORMAT=text/html&I=268&J=647&FEATURE_COUNT=50
>> the output of is as follows:
>> Map X/Y : 390428.846605,68589.162768
>> Map LL : 50.516415,-2.135015
>> When a similar requests are made specifying a CRS of EPSG:4326:
>>    &BBOX=50.33460688675980776,-2.28814701603231718,50.84060858090575863,-1.92285769511938809
>>    &CRS=EPSG:4326&WIDTH=649&HEIGHT=899&LAYERS=test&STYLES=&FORMAT=image/jpeg&QUERY_LAYERS=test
>>    &INFO_FORMAT=text/html&I=298&J=579&FEATURE_COUNT=50
>> the output is as follows:
>> Map X/Y : 50.514437,-2.120136
>> The maplat and maplon templates are not substituted.
>> Mapserver has been compiled with PROJ support and a PROJECTION has
>> been defined for the layer in the map file.
>> The CRS of the source data is EPSG:27700
>> I was hoping that the maplat and maplon templates would provide me
>> with a consistent source of coordinate information, independent of
>> the request CRS. Can anybody shed any light on the observed behaviour?
>> Thanks,
>> Andy
>> Andy Harfoot
>> Skype: gdi_ajph
>> Teams:ajph at soton.ac.uk  <mailto:ajph at soton.ac.uk>
>> Phone: +44 2380 590566
>> GeoData Institute
>> Southampton
>> SO17 1BJ
>> www.geodata.soton.ac.uk  <http://www.geodata.soton.ac.uk>
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
Andy Harfoot
Skype: gdi_ajph
GeoData Institute
Southampton
SO17 1BJ
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20231019/25d8e686/attachment.htm>
More information about the MapServer-users mailing list
