[MDAL-Developer] Volume intrepretation
Martin Dobias
wonder.sk at gmail.com
Tue Aug 24 04:59:24 PDT 2021
Hi Paul
On Tue, Aug 24, 2021 at 1:33 PM Paul Harwood <runette at gmail.com> wrote:
> I should have said that I had studied that doc - and it does not actually
> answer my question. I also looked at the UGRID CF definitions but they are
> deliberately vague about this subject as well - suggesting two possible
> interpretations.
> This problem only really comes to light when you start thinking about
> creating a 3D visualisation of the data.
> The problem is that the doc has two interpretations, which are not
> compatible and neither is properly represented by the data - viz:
> [image: v2.png] [image: v1.png]
Yes unfortunately those figures do not properly represent the data, and
they were meant only for an introduction to the topic...
> I have chosen to interpret the data set as something more like this
> [image: v3.png]
> I think that is correct but it is not clear from the docs and seems a
> little strange as a data structure
Right, that's how I understand the data structure as well. In theory it
could be even more general, e.g.:
[image: image.png]
But I am not sure if such structure of vertical levels would make any
practical use, so this is merely just a theoretical example. In MDAL we
simply adopted the data model of stacked meshes as it is returned from
simulation software (without trying to do any transforms to turn data into
more "regular" structure).
Regards
Martin
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/96040bb1/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/96040bb1/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/96040bb1/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/96040bb1/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mdal-developer/attachments/20210824/96040bb1/attachment-0007.png>
More information about the MDAL-Developer
