[Mobilitydb-dev] Fwd: MobilityDB: Spanish documentation files
Esteban Zimanyi
esteban.zimanyi at ulb.be
Wed Jul 21 23:17:25 PDT 2021
Independently of the releases, I think there are still two issues
* Structuring of the code: I would propose to have the directory
MobilityDB/doc for the XML files of the English documentation and then have
a directory MobilityDB/doc/es for the XML files of the Spanish
documentation. Then remove all transifex files that are anyway outdated.
* Ensuring that the licence check finds the XML files of the Spanish
documentation. According to my understanding this is not the case.
If you agree I can prepare a PR with these changes.
On Wed, Jul 21, 2021 at 5:39 PM Vicky Vergara <vicky at georepublic.de> wrote:
> Hi Esteban.
> I dont mind being asked.
> In general a release should be handled as follows Thinking on rc release
> candidates:
> Freeze code (Allows documentation changes)
> Freeze documentation (Gives time to translators to translate)
> Freeze translation (everything is freezed, so make the release)
> So worry about translation when the documentation is freezed. As code,
> including build code, is not freezed, anything can happen.
> So for example, Soon there will be a 3.2.1 release for pgRouting, and that
> minor (3.2) already has translation, but the documentation will have
> changes. We dont worry about re-translating a minor so the affected
> documentation for spanish will be in spanglish.
> But those changes will be ported to 3.3, and 3.3 will be released on
> october/november, adding new code will be allowed around August, code fixes
> will allowed during a month after that, but most work will be focused on
> reviewing the documentation, translators will have october to translate the
> new/changed lines. And we will release 3.3 at the end of october beginning
> of november.
> Even that you are in a beta version (I think) there are lots of code
> changes like in this PR
> https://github.com/MobilityDB/MobilityDB/pull/83
> So I wouldn't worry about translation yet.
> Now pgRouting have transifex linked to develop branch.
> https://docs.transifex.com/transifex-github-integrations/github-tx-ui
> So the files are allways with the latest content.
> But your repository is quite disorganized still, so it is going to be
> difficult at this moment in time to set up that automatic feature.
> But we are working on it :-)
> Regards
> Vicky
> On Tue, Jul 20, 2021 at 8:37 AM Esteban Zimanyi <estebanzimanyi at gmail.com>
> wrote:
>> Una preguntita Vicky.
>> Me di cuenta que los ficheros docbook (xml) de la traducción española del
>> manual no tenían todavía la licencia y tu script/workflow que verifica las
>> licencias había pasado. Entonces seguro que los ficheros están puestos
>> donde no deberían estar. Acabo de integrar un PR añadiendo estas licencias
>> en la rama develop.
>> Como sabes bien, la primera version de la documentación en español la
>> hice con Transifex, como tú me enseñaste. Sin embargo, en cada nuevo PR que
>> hago añadiendo una función suplementaria a MobilityDB (la última fue
>> asMVTGeom) no puedo recomenzar el ciclo con Transifex porque empieza de
>> nuevo el proceso de cero y eso requeriría un tiempo imposible teniendo que
>> repetir el trabajo ya hecho.
>> Por eso yo mantengo sincronizadas las dos versiones en español y en
>> inglés de la documentación sin pasar por Transifex. En github los ficheros
>> en el repertorio
>> https://github.com/MobilityDB/MobilityDB/tree/develop/doc/po
>> están totalmente obsoletos puesto que datan de la primera vez que
>> utilizé Transifex, aunque los ficheros docbook (xml) en el repertorio
>> https://github.com/MobilityDB/MobilityDB/tree/develop/doc/po/es
>> son los que mantengo sincronizados manualmente.
>> ¿Qué me recomendarías para manejar eso de manera profesional ?
>> Esteban
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> Mobilitydb-dev mailing list
> Mobilitydb-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mobilitydb-dev
URL: <http://lists.osgeo.org/pipermail/mobilitydb-dev/attachments/20210722/c767fbf5/attachment.html>
More information about the Mobilitydb-dev
