[NAS] problem when importing atkis nas data into postgres
Frank Warmerdam
warmerdam at pobox.com
Mon Jul 12 08:41:00 EDT 2010
Armin Retterath wrote:
> hello altogether,
> the problem has s.th. to do with ubuntu 10.04 and the packages
> mentioned below.
> under debian lenny the compiling and import was done well and the
> right datatypes was inserted in the geometry_columns table.
> maybe postgis > 1.3.3 (and or postgres > 8.4) was the problem?
Armin,
Hmm, this is a bit surprising. You are sure in both cases you were building
the same source code for GDAL/OGR?
I see I am running PostGIS 1.4 on PostgreSQL 8.3.7.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
