[OpenDroneMap-users] question about resolution and camera orientation
Anna Petrášová kratochanna at gmail.com
Tue Feb 24 19:58:57 PST 2015
On Tue, Feb 24, 2015 at 10:23 PM, Stephen Mather <stephen at smathermather.com>
wrote:
> Hi Anna,
> Yes "--resize-to" will typically help get you a denser point cloud. I
> have found --resize-to 3000 to be a useful default, though the project
> currently defaults to 2400 to avoid swamping people's machines.
I am currently experimenting with larger images but it takes too long. Just
the matching takes forever. I wonder why the matching is not running in
parallel, if it's not implemented yet, it can't be implemented easily or it
gets confused since I am running it in virtual box?
> There's a lot to be done on the documentation side. Also, while the
> meshing and texturing portions of the codebase are novel, some other
> portions (Bundler, CMVS, PMVS) are projects onto themselves, so it will
> take a bit of exploration to figure out optimal parameters. As we (as a
> community) discover those optimal parameters, we can improve the sane
> defaults, and document good alternatives.
I was looking for some better documentation for these projects, but I
didn't find anything helpful. I wish I would know more about the actual
algorithms, but that's not my background.
> (That said, there is plenty of documentation to be written that I or
> others already know, so that is a priority)
> As to XYZ, yaw, pitch, and roll, OpenDroneMap does not yet take that into
> account. I would be excited to see this, perhaps even using SFCGAL or other
> 3D library for doing proper image footprints a la:
> https://smathermather.wordpress.com/2013/12/15/uas-drone-footprint-geometries-calculated-in-postgis-with-sfcgal-for-real-this-time/
Great blog!
> This would substantially reduce the processing time on the "match" step,
> which is a decent proportion of the current processing time.
> Also, I haven't written any documentation on it yet, but in the bundle.out
> file in reconstruction-with-image-size-2400 can be loaded in Meshlab to
> check camera positions and determine sanity of camera positions. There's a
> youtube video on that somewhere that I'll dig up.
Right, I noticed that.
Best,
Anna
> Cheers!
> Best,
> Steve
> On Tue, Feb 24, 2015 at 1:52 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Tue, Feb 24, 2015 at 1:32 PM, Andy Wilde <awilde76 at gmail.com> wrote:
>>> Hi Anna,
>>> For the resolution issues please read the wiki information which shows
>>> some of the parameter information.  This documentation is still under
>>> development and will improve.
>> Yes, I looked at the wiki, but I couldn't find what I was looking for. I
>> am still experimenting with different parameters so I will see. I will
>> definitely keep checking the wiki.
>>> For the X, Y, Z values the system will interpreted GPS information if it
>>> is in the image data,  I would expect that it will interpret x,y,y values
>>> in much the same way.  For the roll and yaw I do not think it will
>>> recognise this as yet.
>> Thanks,
>> Anna
>>> Sent from Mailbox <https://www.dropbox.com/mailbox>
>>> On Mon, Feb 23, 2015 at 9:28 PM, Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I am trying to run opendronemap on my 200 images and a better
>>>> documentation of the different options would help me a lot. (I know,
>>>> writing documentation is always painful.) So I have a couple of questions.
>>>> 1. How do I increase the resolution? I need the point cloud from which
>>>> I would construct high-resolution raster DSM. Would higher --resize-to do
>>>> the job? Or a different parameter?
>>>> 2. I have the external orientation of camera (x, y, z, yaw, pitch,
>>>> roll), is there any way the algorithms could take advantage of this
>>>> information? I can imagine using these as initial values for the algorithm.
>>>> Thank you for this great software!
>>>> Anna
>> OpenDroneMap-users mailing list
>> OpenDroneMap-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150224/6d8a0db0/attachment.html>
More information about the OpenDroneMap-users mailing list
