[OpenDroneMap-users] question about resolution and camera orientation
Stephen Mather stephen at smathermather.com
Wed Feb 25 08:02:17 PST 2015
Hi Anna,
Matching should be parallelized. What are you running it on
(hardware/hosting, OS)? Just Bundler should be single-threaded, if memory
serves (not that memory always serves). My general recommendation is throw
as much resources as possible. All the test datasets will process in a
couple hours or less on a 32GB RAM digital ocean machine, which costs about
$2 to run. I also have a workstation I do testing on which has 12
processors and 32GB of RAM plus an SSD RAID. That is a pleasant machine to
run datasets on. I know many have had success with larger Amazon instances
as well -- perhaps someone on the list can speak to those experiences.
As a point of contrast, running on a VM on my ultra-book is an exercise in
frustration. :)
If it is a dataset you can share, I can run some tests and see if I am
seeing similar issues.
Cheers,
Best,
Steve
On Tue, Feb 24, 2015 at 10:58 PM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Tue, Feb 24, 2015 at 10:23 PM, Stephen Mather <
> stephen at smathermather.com> wrote:
>> Hi Anna,
>> Yes "--resize-to" will typically help get you a denser point cloud. I
>> have found --resize-to 3000 to be a useful default, though the project
>> currently defaults to 2400 to avoid swamping people's machines.
> I am currently experimenting with larger images but it takes too long.
> Just the matching takes forever. I wonder why the matching is not running
> in parallel, if it's not implemented yet, it can't be implemented easily or
> it gets confused since I am running it in virtual box?
>> There's a lot to be done on the documentation side. Also, while the
>> meshing and texturing portions of the codebase are novel, some other
>> portions (Bundler, CMVS, PMVS) are projects onto themselves, so it will
>> take a bit of exploration to figure out optimal parameters. As we (as a
>> community) discover those optimal parameters, we can improve the sane
>> defaults, and document good alternatives.
> I was looking for some better documentation for these projects, but I
> didn't find anything helpful. I wish I would know more about the actual
> algorithms, but that's not my background.
>> (That said, there is plenty of documentation to be written that I or
>> others already know, so that is a priority)
>> As to XYZ, yaw, pitch, and roll, OpenDroneMap does not yet take that into
>> account. I would be excited to see this, perhaps even using SFCGAL or other
>> 3D library for doing proper image footprints a la:
>> https://smathermather.wordpress.com/2013/12/15/uas-drone-footprint-geometries-calculated-in-postgis-with-sfcgal-for-real-this-time/
> Great blog!
>> This would substantially reduce the processing time on the "match" step,
>> which is a decent proportion of the current processing time.
>> Also, I haven't written any documentation on it yet, but in the
>> bundle.out file in reconstruction-with-image-size-2400 can be loaded in
>> Meshlab to check camera positions and determine sanity of camera positions.
>> There's a youtube video on that somewhere that I'll dig up.
> Right, I noticed that.
> Best,
> Anna
>> Cheers!
>> Best,
>> Steve
>> On Tue, Feb 24, 2015 at 1:52 PM, Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> On Tue, Feb 24, 2015 at 1:32 PM, Andy Wilde <awilde76 at gmail.com> wrote:
>>>> Hi Anna,
>>>> For the resolution issues please read the wiki information which shows
>>>> some of the parameter information.  This documentation is still under
>>>> development and will improve.
>>> Yes, I looked at the wiki, but I couldn't find what I was looking for. I
>>> am still experimenting with different parameters so I will see. I will
>>> definitely keep checking the wiki.
>>>> For the X, Y, Z values the system will interpreted GPS information if
>>>> it is in the image data,  I would expect that it will interpret x,y,y
>>>> values in much the same way.  For the roll and yaw I do not think it will
>>>> recognise this as yet.
>>> Thanks,
>>> Anna
>>>> Sent from Mailbox <https://www.dropbox.com/mailbox>
>>>> On Mon, Feb 23, 2015 at 9:28 PM, Anna Petrášová <kratochanna at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> I am trying to run opendronemap on my 200 images and a better
>>>>> documentation of the different options would help me a lot. (I know,
>>>>> writing documentation is always painful.) So I have a couple of questions.
>>>>> 1. How do I increase the resolution? I need the point cloud from which
>>>>> I would construct high-resolution raster DSM. Would higher --resize-to do
>>>>> the job? Or a different parameter?
>>>>> 2. I have the external orientation of camera (x, y, z, yaw, pitch,
>>>>> roll), is there any way the algorithms could take advantage of this
>>>>> information? I can imagine using these as initial values for the algorithm.
>>>>> Thank you for this great software!
>>>>> Anna
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150225/842ef843/attachment-0001.html>
More information about the OpenDroneMap-users mailing list
