[OpenDroneMap-users] Newbie focal length override
Stephen Mather stephen at smathermather.com
Sun May 10 15:27:07 PDT 2015
Hi Howard,
Welcome! Try forcing the ccd size. Did you do any barrel distortion
correction first? This is something ODM doesn't do well (yet) as it only
does 3-parameter (not 6-parameter) distortion corrections. This is
something that needs worked into the toolchain in the near future.
References:
There's a calibration class up here from Cole:
https://github.com/colek42/TrackIt/blob/master/catkin/src/stabilize/src/calibrate.py
plus Alex' work here (GoPro2 only, but a good example):
https://github.com/wildintellect/lenscorrection
Finally, see Jan Erik Solem's work here for a full calibration solution:
http://www.janeriksolem.net/2014/05/how-to-calibrate-camera-with-opencv-and.html
Once you've done the correction and cropped, you'll need to estimate the
ccd size of the cropped area, I think, and then it should feed in just fine.
Cheers,
Best,
Steve
On Sun, May 10, 2015 at 1:20 PM, Howard Butler <howard at hobu.co> wrote:
> All,
> So I have a 2 min 720 video from a GoPro Hero 3 Black that I ripped out
> 126 images out of using ffmpeg. I want to attempt to start with that.
> When I attempt to run them, I get the following error:
> > no CCD width or focal length found for image-100.jpg - camera: “ "
> Of course this is a FAQ, but my pattern isn’t quite the same. If I try
> —force-focal 5.76, which is the GoPro entry in the json file, it still
> blows up.
> Ideas?
> Thanks,
> Howard
> OpenDroneMap-users mailing list
> OpenDroneMap-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/opendronemap-users
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20150510/c3b962ef/attachment.html>
More information about the OpenDroneMap-users mailing list
