[OpenDroneMap-users] Multicore/SMP performance
Piero Toffanin pt at masseranolabs.com
Sat Jun 3 06:56:44 PDT 2017
Yes you can take non-nadir pictures. You can also take both to get
better overhangs in the textured mesh. ODM will merge them together.
For the resolution, increase the --orthophoto-resolution parameter to
something like 60 for a better orthophoto. I think the textured mesh
already uses the highest resolution available, but perhaps try to
increase the -- resize-to parameter, maybe that will help?
On 06/03/2017 09:51 AM, StuartL wrote:
> Thanks, Piero.  That explains all.  FTR setting that to 4 worked for
> me and didn't hang up.  Admittedly I'm only use four cores so any SMP
> race conditions/deadlocks etc are much less likely to affect me than
> someone running on 64 cores.
> Very impressive results, 82 photos taken at 3m intervals, 30m altitude
> using a Phantom 3 Advanced.
> Out of curiosity: If I take photos with non-vertical orientation, e.g.
> pointing the camera sideways or at an angle, can ODM automatically
> integrate the results and avoid the voids under overhangs?
> I'm so impressed with this software and thank the developers for it.
> If I had one wish it would be to get slightly higher resolution
> results.  Some of the detail from the original photos is lost in the
> textured mesh.  Is this a tunable parameter or a limitation of the
> current implementation?
> Stuart
> On 03/06/2017 14:22, Piero Toffanin wrote:
>> Hi Stuart,
>> You can use more cores by setting the "opensfm-processes" option. By
>> default we've set it at 1 because a fault is causing the program to
>> get stuck sometimes with more cores:
>> https://github.com/OpenDroneMap/OpenDroneMap/pull/579
>> Increasing the number of cores at compilation does not influence
>> runtime behavior, it just compiles faster :)
>> On 06/03/2017 06:54 AM, StuartL wrote:
>>> Hi,
>>> I'm running a new install of ODM in a VirtualBox Ubuntu guest VM on
>>> Windows.  The guest VM has four cores but ODM only seems to use one
>>> core.
>>> Looking at some other posts people seem to be talking about using
>>> massive numbers of cores so I feel like I must be doing something
>>> wrong.
>>> Possibly relevant information:
>>> - ODM was originally compiled with only one core in the VM.  I later
>>> increased the number of cores.
>>> - I'm measuring it using one core by monitoring with 'top' and
>>> pressing '1' to reveal individual CPU cores.  At all steps so far
>>> (currently up to Computing depthmap for...) it seems to flatline one
>>> core but the others are nearly idle.
>>> Does it deduce the number of cores at point of compilation? Do I
>>> need to enable something to allow multi-core support? Are the steps
>>> I've observed so far all single-threaded?
>>> Thanks for a wonderful piece of software!
>>> Stuart
>>> OpenDroneMap-users mailing list
>>> OpenDroneMap-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/opendronemap-users
*Piero Toffanin*
IT Business Consultant
masseranolabs.com <https://www.masseranolabs.com>
+1(218)461-9746 <tel:+12184619746>
**@pierotofy <https://www.twitter.com/pierotofy>
pierotofy <skype:pierotofy?call>
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0007.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/opendronemap-users/attachments/20170603/bfb95b31/attachment-0001.jpg>
More information about the OpenDroneMap-users mailing list
