[OpenLayers-Dev] GML Help: differentiating properties of SVG
layers and get access to elements
Cameron Shorter
cameron.shorter at gmail.com
Wed Nov 15 05:49:50 EST 2006
The vector code is still in heavy development at the moment, so
everyting that you try today might change tomorrow.
At the moment, I don't think the style object is used by the renderer
yet. Maybe you would like to help us write it?
I think Bertil and Paul Spensor are working on this part. I suggest you
log onto IRC: irc://freenode.net#openlayers if you want to help. (I'm
about to go to bed, but look out for Bertil and Pierre in the European
time zone).
Maurizio Boscaini wrote:
> I'am using the vector files in the sandbox and I've two questions:
> 1. I want to put on a map two GML layers with different strokeColor,
> I've tried writing:
> layer1.renderer.style.strokeColor = "green"
> but this affects also layer2 not only layer1 when the map is painted
> 2. I'd like to differentiate with strokeColor or different markers not
> only two different layers but also different elements in the same layer,
> is it possible? Can I get access to the SVG DOMs of the layers?
> someone can help me?
> mauri
> ps. thanks to all developers for their great job!
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Cameron Shorter
http://cameron.shorter.net
More information about the Dev
