[OpenLayers-Dev] Exact bounding box of WMS untiled request
David William Bitner
david.bitner at gmail.com
Wed Apr 25 13:56:00 EDT 2007
Ed,
Can you explain what you are trying to do? Why do you need the exact
dimensions?
David
On 4/25/07, Ed Fialkowski <edfialk at gmail.com> wrote:
> Something else I wanted to note, if you see my page at
> http://niceguy.wustl.edu/openlayers, for either one of the maps at the
> bottom, select EDGAR from the dataset and hit submit.
> Now, drag the map all the way to the west (so you can see more of the
> east).
> The max extent, ratio, and all that are set for this map, but after
> dragging it, the area to the east is still being downloaded from the WMS
> server. If you vew the image location here, you'll see the max longitude is
> up to about 90.
> Again, this is very bad for me.
> Any ideas?
> -Ed
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20070425/cd6dfd33/attachment.html
More information about the Dev
