[OpenLayers-Dev] Vector layers seem to block mouseover/mouseout
events from lower Marker layers
Erik Uzureau
erik.uzureau at metacarta.com
Thu Jul 19 17:41:19 EDT 2007
A workaround for this might be using that Image-as-Vector thing that
someone added as a patch just recently?
Chris do you know what I'm talking about?
erik
On 7/19/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> On Thu, Jul 19, 2007 at 05:17:22PM -0400, Peterson Eric-EEP002 wrote:
> > Is this the way it's supposed to work? I'm hoping that there's some
> > Layer option that blocks propogation of events to lower layers that I've
> > forgotten to disable. But I've thumbed through the code and the apidocs
> > for Layer and Vector, but I didn't see anything immediately obvious.
> This is the way it does work, and there is currently no workaround for
> it. The SVG element has to fill the div, and when it does, events don't
> drop through to the layers below.
> There is no work being done on a fix for this, because I believe it's
> just 'the way it works' -- I don't think we can do anything about it.
> Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
